lastcowboy32
My Ford 3000 has been mostly parked for the off-season since about two months ago. With the exception of starting it every weekend to run it and using it to move some wagons around when I parked the haying equipment. It was outside up until about two weeks ago.
Once I got the hay loft all cleaned up and situated for winter, I drove it up the ramp and put it under cover.
Since then, it's on a battery maintainer, and I start it once every weekend for fifteen minutes or so, just to keep the engine lubricated and loose.
We had an oddball cold snap before the last time that I started it. It was below 32 for a few days in a row. When I got on that Saturday, it started, but when I let out the clutch, it would kill the engine.
Now, this isn't a situation like my old 2N, where the hydraulic pump only runs when the PTO is engaged and the clutch is let up.
The hydraulic pump in a Ford 3000 should be running all the time, right?
All that I can think is that there is SO much water in the hydraulic fluid that it froze the transmission so solid that, even when it's not in gear, I can't let out on the clutch.
It's been more seasonable this week and supposed to be in the forties this weekend. I'm thinking that I need to get it started and get it into the garage to change all of the hydraulic/transmission fluid.
As a side note, we got 10 inches of rain this October. A record for us. If there ever was a fall that a tractor sitting outside would get some water in it from a cracked shifting lever boot, or whatever...this would be the year.
