mdm1
- Location
- Onalaska,WI
Cub lo-boy started and ran good. Mowed about an hour. At the start the engine would idle and throttle up. After mowing shut it off and started it and it shows no response to the throttle. Runs at the same speed it did when I was mowing. I had changed the carb so I thought maybe the rod to the carb had come off. No luck. When the engine is running I can't move the throttle rod at the carb. If I shut it off the rod and throttle plate move as they should. Only replaced carb didn't touch any of the linkage rods. When you move the rod you can feel spring tension on it. It doesn't just slop back and forth.
