I am working on a carb issue and I put the carb back on after i think i got it sorted. But now the tractor won't crank. Press the start and not a sound.
It did this before and I tightened up the wires on the block and ignition switch and remade the wire end on the solenoid that runs to start button, Then it did fine.
I was literally cranking it yesterday. Battery is brand new and full charge. I have a tester light and everything lights up.. I noticed after it didn't make a sound some wires had slipped off wire block behind dash. Do they need to be in a set order?
I press start and not a sound but yesterday night it was fine. Only change is those wires slipping off. Again, everything lights up with tester light. It's something small. Some wire isn't connected all the way or if there needs to be an order it's off. Solenoid is new. Again - this isn't anything crazy wrong. It's something tiny.
Thanks.
Thanks.
