We had a Bad wind storm recently and a tree fell down on the Tri-Plex wires to the Farm house Meter. Wires were strained and twisted around and at least one seem to be torn lose. Any way there was still at least some power in house that only about 3 lights worked and 1 blew out when switched on. After a week of being in this situation I happen to try the hydrant and it seemed like good pressure yet which surprised me since we have the garden on a timed system.
Our pump is 220 volt submergible pump with pressure tank and appeared to be running and pressure was 30 PSI a week after storm. After turning all the breakers off at box including the Main breaker I still had power at the pump. I do have a little clock w/light wired on one leg of the pressure switch. Not sure if the pump was running but the only way to cut the power was taking the wires off the pressure switch. Voltage at the pressure switch wasn't a clean 240 volt but weird 85-90 volts. How could this pump still be getting power with a messed up service line and all the breakers off?? Would the pump still function with compromised service?? Power company has came and repaired service lines and now every thing is working fine. Sorry for the long post but how was this pump getting power??
