Paul 300 U
Jim. Thanks. I'm going to start with the distributor. I never forced anything. I was concerned that everything might not be assembled correctly (apparently I was correct) so I firsttried to rotate it with the hand crank, I never used the starter, so I'm hoping there are no broken teeth.A tenth of a turn is maybe 10 to 15 teeth on the ring gear. That is not enough to get close to a full stroke in a cylinder. Thus what ever it is is happening within a short piston travel, or cam shaft movement. tooth off of a cam gear, or distributor locked up from a long screw in the breaker plate or other "quick" thing stopping it. I would use an endoscope (cheap tool with a smart phone) to look around in the cylinders. I would also remove the distributor to see if that could be locking it up. I would search until i find the issue and for sure not force it through. Jim
I do have a phone scope. Are you recommending I remove the oil pan and head to get a look at the cylinders or try to fish through the plug openings. Feel free to add detail, you are well aware of my mechanical acumen! Paul
