used red MN
- Location
- Coon Rapids, MN
I recently helped a young man 14 or 15 years old via long distance communication with repair of his TA in his 450. He had the TA just about stripped down to nothing repairing the one-way clutch and fixing the direct clutch as well. This kid has impressive knowledge and mechanical ability. He called me from a show he took it to saying his hydraulics had quit namely the power steering but also the fast hitch stopped working. He said it worked fine at the show after he first got there. He shut it off I believe overnight and the next day it did not work. He says the hydraulic pump is warming up quickly when it is running. My question is if the pilot system orifice is plugged and holding the system on pumping or operating pressure would the fast hitch still operate. I have initially told him something in the Regulator Safety Valve has a problem. Can anyone confirm that the parts 16 - 22 is the valving that controls the flow to the power steering? Another listing for the Regulator Safety Valve is shown in subsection 380 but ..flow control.. is not in its description and the above mentioned parts are not shown in it so I am deducting that those parts are for a PS equipped tractor. Ryan currently has a post about his brakes on the 450 in the Restoration and Repair Tips. Due to some of the more technical terms of this post I am placing it here for his information. BTW, the hydraulic system is full and everything has worked properly for multiple days when operating the tractor. Any tips or other info concerning his loss of PS and remotes would be appreciated. TIA!
CNHI F450 diesel hyd subsection 377
