OK, I want to get my farmall cultivator set up. It came with a read spring toot tine harrow and under the belly is basically a setup that came with two rolling disks. Presumably, this is for hilling. Anyway, the shank that sits under the clutch housing is far too long. Both shanks are the same, but you cannot raise the implement high enough to get the disk off the ground AND not jam it into the belly.
So, I took those off and put four cultivator shanks on the same bar. It has the same problem. It seems to me that I need four shanks but they all need to be different lengths.
Anyway, Where can I get a SHORT shank?
Also, it seems there are multiple styles of spring shanks. Mine came off an old B450 cultivator so they are spring loaded with two notches. They don't 'trip'. I don't know why there are two notches, but at any rate, these just 'give' and the spring pushes it back.
The other style I see it the kind that truly trip and you have to reset. I don't care which style I use as long as they fit and work under the belly.
Can someone help me understand all the types and lenghts? My shanks seem to be about 7.5" long or so, but if they were about 2-3" shorter, that would be about perfect. As it stands, the cultivator can only be lowered to the first notch or two. There are about 10 notches.
