Farmall H hitch and drawbar
dew67
Does anyone know of a Farmall H hitch and drawbar for sale near southern Colorado or northern New Mexico?
I have a parts 1940 H but I am in Missouri
I need the complete hitch including the mount for the axles and the drawbar including the drawbar pin. If you have all this, how much are you asking for it$
Post an ad in the Marketplace above. Long shot that someone in this relatively small community will be near you with what you need, but it won't hurt to explore all avenues.
Fortunately the H is one of the most common old tractors out there. In any community where there was any agriculture at all there's likely to be one of these sitting in the weeds. There are also likely to be many of them sitting in old tractor salvage yards. Old school salvage yards tend to be hidden gems, rarely advertised so you'll need to ask around locally.
Tractor show season is starting, and along with them, swap meets and flea markets. Plan on attending and when you see a guy selling tractor parts, especially old IH parts, talk to them. They likely have, or know where to get, what you need.
Shipping would probably be expensive but JP tractor in MO would have the parts and ship to you . It's worth calling John
The square tube would be easy to make for the mount the bolts would be able to be tightened across the axle with long 5/8or 3/4 bolts for the other bolts you would need the eye bolts for the tube as they swivel in the tube about 90 degrees. OR you could just use bolts through the tube and cap it so it doesn't crush with tightening and pulling loads or weight from drawbar weight. Was your missing or broke from to much weight? We have welded them back together then added a piece about 3/4 thick to the top of the original drawbar both the u bar it swings on and the swing piece that you hook to. Had to do both our H and MD. Also had to improve our 1466 after we broke it pulling the chisel plow with it.
