cnj 152, fixerupper, fixer2u, Mike Fitz, John Saeli, old prouduct, Bruce from Can.
Thank you for all your suggestions. They were great. As you recall I was having trouble with my 830 stumbling. After it was back in the barn, I drained all the gas out of the tank (about 4 gallons). Before going any farther with the trouble shooting, I pulled the fuel separator. Low and behold there were three gas soaked seeds in the neck of the separator. I tried blowing through it with my mouth on the intake end. It was very hard to get any air through. Removed the seeds and cleaned the intake. I was then able to blow air through it fairly easy. I have now run the tractor several times and it works great. No stumbling. The flow I had with the seeds in place was about .125 inches and was constant out the bottom of the carb. Now the flow is about .250 inches. Remember it drained the 4 gallons with no problem or stoppage of flow. Did not have to replace any parts. However; I soldered up a two inch strainer and put it on the intake of the separator to help prevent future blockages.
John Sali, you hit the nail on the head.
Thanks Again
Thanks Again
