Hello. First post here. Have a Ford 1700 with a starting issue. Should say at beginning very inexperienced working on tractors or engines but since I have a 40+ year old tractor have to try.
When key is turned to on the two red indicator lights come on. Preheat will work. But will not crank. Checked fuses and checked and cleaned all the electrical connections I can access. Battery charged. Can't open hood because aftermarket loader is in the way and I can't lift loader since it doesn't run.
Carefully tried to start tractor with the screwdriver on the starter method. Starter runs but does not engage. Might that have something to do with the third, blue, wire running separately to the starter? And is there anything I can do to start it and get the hood up?
I'm guessing it might be a bad ground somewhere I can't reach or see. But that's just an uneducated guess. Tractor sits outside. I try to start it regularly but sometimes forget. Starter is only two years old.
Any help greatly appreciated. Been trying to get it going for a week now.
Thank you.
Francis
Thank you.
Francis
