Woodtractor1
I have a 1959 ford 172 gas engine in a an old omc770 wheel loader. I swapped the engine from a diesel that blew up about 6 months ago. The gas engine ran well for about 4 months, maybe about 4 hours of total run time. Then it started running really rough, so I replaced the points only. It still ran terrible. I replaced the condenser and it ran great, for about an hour of run time. Then it started running rough again. Sputters under throttle.
I replaced the condenser again and it ran well for about an hour of run time. I don't know where to go from here or what to check. Any suggestions are greatly appreciated.
Please let me know if I need to provide more information.
Also, the condenser isn't screwed down because the screw hole is stripped.
This happened because the replacement condenser bracket strap was slightly larger than the original and i stripped it. But it ran well without it being screwed down for a bit.
Thanks!
![20241010_152902.jpg 20241010_152902.jpg](https://forums.yesterdaystractors.com/data/attachments/89/89912-81202c8bdf1855e559d92ba6ffee1fc9.jpg)
![20241010_152911.jpg 20241010_152911.jpg](https://forums.yesterdaystractors.com/data/attachments/89/89913-9eb4abeb2488a622d55e55d6899b11d4.jpg)
Thanks!
