Jim.ME
- Location
- central ME
This may have been asked and answered. Is the little clip on the distributor shaft in place under the rotor button to hold the button in alignment?
Try closing the points down to .022" and run a clean piece of uncoated card stock or brown paper bag (even a folded-up dollar bill between the point contacts to clean them when you finish.Yes it is. Thanks.
I finally had opportunity to try and diagnose my tractor further: I did spray carb cleaner around the intake connections(I also tried this with propane). This did not change the condition at all. I also took carb off again and cleaned all passages with tip cleaners. This also did not produce any improvement at all. As stated before, if carb is the problem, I cannot understand how. If it is, I will need a new one, but I am certainly reluctant to buy new. These carbs are so simple, it is hard to see how this is my problem. The condition I am having will not change at all by choking the carb.
Next I did a more complete analysis of the spark. Here I found an issue, not sure what is causing it, could be the problem: The spark is very nice blue/white spark, on all 4 cylinders will jump 1/2". Removing one at a time definitely causes an engine miss in each. I decided to eliminate plug wires, so I used a new piece of copper core cable to test from the cap towers. I eventually noticed that the spark though strong, was intermittent. Sometimes seeming to skip several cycles and then fire again. very irregular, and it does not seem to be dependent on rpms. I guess I am going to have to replace cap and rotor again from a different source. Not sure what else could cause this condition? I had another rotor button and tried it so I am now on my second cap and third rotor, with no change whatever in the symptoms. I am still busy with care of my mom and other tasks, so again not sure when I will work on it again.
#63 to get to something to work with why would you still be fudgen with the fuel its not going to help what you found.Jim: I will retest the fuel flow as you suggested. Thanks
Your problem is most likely in the primary sideYes I have checked for lateral movement of distributor shaft, not certain, but it seems ok. Points are new. I am obviously needing to dig deeper to find the problem causing the erratic spark. The spark is so strong, it seems the problem must be in secondary distribution of the spark. However at this point I am retracing my steps in the whole ignition system. I will be going through the distributor completely for fourth time, likely will find a NH dealer for some new parts. Thanks guys
I suggested that at reply #52.Another thing to check on those distributors is the wire that goes from the coil down through the base of the distributor to the points. Sometimes the wire insulation gets worn where it goes through the wall of the base of the distributor and it can short to ground.
You may have a bad condenser. I'd change that out and put in new points while you're in there.I finally had opportunity to try and diagnose my tractor further: I did spray carb cleaner around the intake connections(I also tried this with propane). This did not change the condition at all. I also took carb off again and cleaned all passages with tip cleaners. This also did not produce any improvement at all. As stated before, if carb is the problem, I cannot understand how. If it is, I will need a new one, but I am certainly reluctant to buy new. These carbs are so simple, it is hard to see how this is my problem. The condition I am having will not change at all by choking the carb.
I have never seen a condenser fail intermittently they die that's it you will have constant weak spark a no brainer IMHO. Its worth a try I am not betting on it.I suggested that at reply #52.
I believe he has a failed CONDENSOR. It is failed open so it is like it is not there.
I also gave that advise in reply 52.
Keith
I guess it would depend on where he got his points and condenser. If they are Chinese knockoffs, anything is possible.I have never seen a condenser fail intermittently they die that's it you will have constant weak spark a no brainer IMHO. Its worth a try I am not betting on it.
I will try this again.Previous sent to soon! My keyboard work is terrible. Hobo I somehow missed your post #70. In order to get a better look at the primary side I will need to spend some time with a meter. The thing that throws me off is that it seems like with all the parts I have changed, the condition I am seeing should have changed at least some. For that reason I am beginning to think there is something small thing somewhere that I have not found. I will definitely post back what I find. Thanks
New does not mean much anymore I have had my share of bad contacts out of the box have you cleaned them with emery cloth?Sean, Keith and Recoil: The wire connection going into the dist. is good, has been double checked. Points and condenser are new, but I will try from NH dealer. Coil is new, cap and rotor are new. Regarding parts, I am not sure even the dealer parts are not made somewhere in Asia. At this point it is obvious there is something I am missing, or replacement parts that are bad. The saga continues! I say again how much I appreciate all the help found here. I would sure like to get this thing going, I have a tree or two I need to get cut, and will need to drag logs to the woods.
Doug
