Hello all, I just bought a 1964 Ford 4000 with the 4 cyl gas engine and SOS trans. I am new to AG tractors but have worked on cars and heavy machinery. I cannot figure out why my PTO won't engage. The PTO free spins while running the tractor with and without the lever being pulled. Even if the lever is pulled I can stop the PTO shaft with my bare hands. I let go and it spins again. I found this out when I hooked up my bush hog and it wouldn't spin it at all. The bushhog works fine and isn't locked up. All 10 forward gears and 2 reverse gears work fine. No matter how high the tractor is revved the PTO wont move when hooked up to the bushhog. The rear (diff) fluid is at the proper level but does have some water in it (yes I am going to change it). Transmission has the elbow piece on the fill/check port and I could see some fluid at the bottom of the elbow. Pressure gauge shows right over 50 with or without PTO engaged. I have both manuals that everyone recommends in the other threads on the way but need this fixed soon. Any help is much appreciated
