Grown_in_gravel
Bringing up my 4500 backhoe for the first time with:
-New Crank, rings, pistons, bearings etc.
-Valves reground and reseated
-Rebuilt Generator
-New filters all the way around (fuel, oil, power steering)
-New injector tips and tested for proper leak down and release pressure
After lots of starter issues, I got it running. After running out of fuel due to a plugged petcock, cleaning out the tank and rebleeding it, it now smokes slightly and seems to have low contribution on #1. I determined that by cracking open the injector line at the injector and it had much less change in RPM than cracking one at a time the other two injectors. I pulled #1 injector out and it passes leak down and has a good pattern. I've got some ideas but wanted to toss it out there for the group to comment on. Here is a link to the video of it running before tank plugged & running out of fuel.
PS. Cant figure out how to lube the throughout (release) bearing. It's got some sort of threaded on grease pot. Barely a mention of it in the service or operators manual.
Comments/flames welcome.
-Rebuilt Generator
