Hello all,
I'm restoring a 68 Ford 8000. When I got the tractor, the motor was stuck, and I have no history on it. I decided to disassemble tractor and the motor. To start off I drained the oil and found about 5 gallons of water/antifreeze mixed in there. So right away I figured the cylinders cavitated. So since then I've taken the motor all the way apart. Now i'm not an engine builder but the inside of this motor really doesn't look too bad. The main and rod bearings have little to no scratches or grooves on them. 2 of the 6 cylinders were "frozen" in place, and I hit them out with a block of wood from the bottom to the top. These cylinders had some rust built up, so I cleaned them up and honed them. There is some pitting in these, but unless the pitting has miniature caviation holes in them, i'm not seeing how 5 gallons could have gotten mixed into the oil. So at this point im not sure what to do....the tractor will not be in the field working very much for the rest of its life, I just want to get it running and complete small tasks with it. Where else could this coolant/water have come from? Is there a common place to be looking for cracks? or freeze plugs? Also how much pitting is too much for this motor?
thanks in advance! I'm sure ill have a million more questions!
