Centerline
The fuel shutoff valve is leaking on my 850 and I'm trying to figure out what is needed to gain access to repair it..
The tractor is fitted with a Ford front end loader, which I'm hoping the hood can be removed without having to dismount the loader frame from it... And does the entire engine hood need to be removed, or just half of it?... Or can the bolts be removed from the tank allowing the tank to be lifted and turned enough to access the shutoff valve?... It's leaking between the tank and valve mating surfaces and barely has room there to fit my big hands to turn the valve on and off... Where do I Start? Thank you..
