Ford 960 Power Steering Hydraulic Hose Replacement
Btzj02
I have to share this experience replacing my Power Steering Hydraulic Hose. The Hose I had was in pretty good shape but due to the 3/8 tube connected to the Pump the hose would kink during a tight right hand turn. Messick's says the original hose is no longer made but they have one available for $225. I decided to try buying what I needed from Discount Hydraulic Hose. They have information on their website to help with identifying the hose fittings you may need. Once I had the fittings identified I had to decide how long the assembly needed to be. I ordered a 30 inch assembly which in hind site may be a little long but if I had the original OEM hose to measure it would have been perfect. My delivered cost: $47.37.
PXL_20240323_204749502.jpgPXL_20240302_161614840.jpgPXL_20240302_162500485.jpgPXL_20240323_213559057.jpgPXL_20240323_215207196.jpg
It would have better if it was designed to have the cylinder mounted the opposite way so that the lines connect to the end of the cylinder that doesn't move.
