G1000 Vista transmission pressure gauge not working.
Tstud
Location
Cent IL
I found a 1967 G1000 Vista that is fully restored, but after setting for a while the transmission pressure gauge doesn't work, the left brake won't pump up, and the PTO turns continuously. Any ideas? Not enough info?
The pto brake is band is either missing or broke.
Should add it could be out of adjustment also. You will have to remove the seat and rock shaft housing under the seat to get to the adjustment screw and to even be able to see anything. A good cherry picker or shop crane will do the trick. I just pulled all those parts off a G1000 and pulled it as a complete unit. Wrap a chain around the three point arms, and a chain or strap around the rock shaft cylinder housing in front of the seat and lift it off. Basically your making a three point lift. It's easy to do, but the assembly is heavy.
