Picked up an IH350 Utility that had set a while.
Carb was dry and rusty as was the fuel tank.
Pull carb and soaked in carb cleaner snd then in ultra sonic cleaner and blown out good. New carb rebuilt kit in it. Adjusted carb to settings in manual.
Used 30% vinegar to clean out the fuel tank. A lot of rust came out. Rinse and dried it good.
Put a Autozone in-line filter on it.
Problem-getting rust particles in to the needle valve seat which blocks fuel flow or limits it which also prevents the needle valve from closing completely. Have had the carb off 3 or 4 times cleaning and blowing out. Finally got the tractor to run good. Drove it around the yard and up the road with plenty of power. However after I shut the tractor off gas soon started pouring out the throat of the carb.
So the needle valve is not shutting off. The needle valve seat and needle are new.
Is there a better filter to use than the cheap inline ones?
Float is set correctly.
