oldfarmall
Hello-
I recently bought a Gehl 135 Mix All feed grinder as a mechanics special. It needs alot of work, but I think I can get everything working good enough to grind a few loads of corn each year for my small beef cattle herd (currently 5 head). I need to go through the hammer mill and turn the hammers as they are badly rounded on the current edges of the hammers. I only have one screen with hole size 3/8". Couple of questions:
1. I assume the hammers are heat treated and not mild steel? Seems they would be easy to duplicate from flat stock?
2. Are the hammer shafts also hardened steel? Can a guy make new hammer shafts if they are grooved badly, and what kind of steel?
3. Do the hammer spacers need to be replaced when hammers are turned? Any idea how to tell how much wear the spacers have?
4. How compatible are the screens between Gehl mixers? What other models used same screen. Are all the 21" wide hammer mill screens the same dimensions and interchangeable aside from hole size?
Thanks for any advice or comments in advance!
-Jesse
-Jesse
