I just got a new unloading auger for my K2 Gleaner and need to swap over the shock absorber, however when these were made someone got the bright idea to heat the tubing and mushroom the metal against the shock absorber. They did that about 8 times, I was going to cut the tubing off of it and remove it that way but its going to be a lengthy process esp when these areas won't budge. The parts book shows 3 bolts to be used with the shock absorber but mine has no bolts or holes for any bolts, the new auger has a couple holes where the shock goes, anyone ever run into this?? I've attached a photo of the trouble spots.
