52farmall
I recently pulled the Zenith carburetor off of my 1956 Farmall 100. I planned on doing a rebuild kit but haven't gotten to it yet. I needed to move the tractor and re-installed the carb but when I went to reinstall the rod that goes to the governor rockshaft arm, the clevis didn't line up with the governor arm. I followed the procedure listed in the manual for setup, wide open throttle, holding the governor and rod all the way toward the carb, etc. They just won't line up like before. I adjusted the clevis on the rod going to the carburetor and I just don't have enough thread to shorten it, it's way too long. When I did start up the tractor when I reattached it, it ran at wide open unless I push the rod forward toward the governor and hold it. I can fiddle with the adjustments enough to get it to idle but there isn't any throttle response until I reach about 3/4 throttle then it goes from idling to almost wide open.
I now have the carb kit and plan on rebuilding it in the coming days. I also took the governor housing off and ordered the main spring for it. The one that is currently installed doesn't feel stretched out or worn and actually feels pretty tight. The weights move freely and the thrust bearing seems fine. I'm at a loss at the moment as I don't know if it's a carb issue, or a governor issue. I've searched the forum, google, and YouTube, but each governor scenario seems different from mine and there just isn't a lot out there about them that I can find. Any guidance or advice is appreciated!
