Grain Drill Setting for Milo or Hay Grazer???
Help, please . . . I'm trying to plant some "hay grazer" (sorghum-sudangrass hybrid) with my old grain drill. The seed looks like bb's./milo/grain sorghum. My grain drill has no setting with this name. The drill is a John Deere Model B 12 x 7. The "notches" read 0 to 60.
I want to plant at a rate of about 50 pounds per Acre. Setting of about 8 or other, better setting??? Thanks for the advice. kelly
Is the B the same as the FB, just without the fertilizer box? If so, the manual I attached below here, might help. The seed looks larger than I had thought, so maybe a hemp setting? If your drill still has one, of course.
Mike
  • OMM2355.pdf
50 pounds per acre sounds high. Especially dry land farming (Kansas).
That rate sounds really high, the milo we'd combine for grain dad would shoot for 5 pounds to the acre. It's been 20 years since I've drilled milo, it was really hard to pinch it closed tight enough.
50 pounds would be about twice what we planted with a B series van brunt drill. Certainly not more than 30 pounds. But, it depends on how much rain you get, and the lighter seeding rates would produce a larger stalk with more height. Sometimes you might want a higher seeding rate to get more foliage with finer stalks, which is usually preferred for baling.
Everything you need to know is in the linked thread. Always calibrate on row feet IMHO. You don't need charts.
