Fred Werring
- Location
- Winchester, Ohio
The instructions say
Make sure the Load Knob (C) is in the off position. Connect the red (positive) Cable
Clamp (A) to the positive terminal (+) on the 12 V battery. See photo on page 4.
Connect the black (negative) Cable Clamp (B) to the negative terminal (–) on the battery.
Turn the Load Knob (C) clockwise until the DC ammeter reads 1/2 the Cold Crank Amp (CCA) rating
Maintain load for 15 seconds to simulate an actual load on the battery.
After 15 seconds has passed, the unit will sound with a beep.
View the DC Volts Meter and read the battery condition. Refer to the "Battery Condition Analysis" section on the next page.
Turn the Load Knob (C) counterclockwise to Off, and remove the Cable Clamps from the battery
So you're looking at the battery voltage while under load to determine if the battery is good. At least that's the way I've been doing it. For years.
Tripped across a youtube video, they're turning the load off, then looking at the battery voltage.
I thought 'this can't be right' , so checked out a few more videos AND THEY ALL REMOVED THE LOAD BEFORE CHECKING VOLTAGE.
So they have me second guessing myself...which way is right?
