showcrop
(quoted from post at 17:40:34 05/19/23)
This is how I've settled on building my wagons. The one in the pictures is 8'3" wide and 20 feet long. It is the 4th or 5th one I've built, and I've built one or two since it, but it is about the optimum size and design for what I do. It has the most angled back backboard of any I have built, and is also the widest, and the hay stacks the best on it of any I have built. I can put around 120 bales on it stacking 4 high with it hooked to the back of the baler, or I could easily go 150-200 bales if I wasn't on such hilly land. The one in the picture is also on a home made running gear that I made from junk odds and ends I had laying around.
I have built them as small as 7'10" x 18' and as large as this one. I normally use 6" or 8" channel for the main runners if I can get it, but have used other scrap steel. My next one will probably have oak 3x8 runners since I have a sawmill now and can make my own lumber dirt cheap.
I bale anywhere from 500-2500 bales in a year, so I am definitely I small time operator. I use either a Farmall M or a Farmtrac 35 to mow with a New Holland 472, A John Deere 1050 with a two basket tedder, a Farmtrac 35 with a V rake or JD 1050 with a NH 256 rake, and a Massey Ferguson 35 with a New Holland 311 baler. My goal is to build 10-15 wagons and have enough barn space to bale straight onto the wagons and park them in the barn without ever unloading, until they are unloaded unto the customer's truck or trailer.
I have very little money in my wagons, just a little time, so if you are so inclined you can expand your wagon fleet without spending a lot of money.
I see no where near enough strength to hold that back rack if your front axle should happen to get two inches higher than the rear.
