Help...delco distributor woodruff key size??
Staner
Working on a JD model A and I'm trying to determine what size woodruff key is used on the Delco 1111558 distributor to hold the lugs on the shaft. I have tried a few keys I have around here but can't find exactly what size is used. I know I can buy a rebuilt kit that includes that woodruff key. I am just trying to get it back in working condition as soon as I can, and shipping for that $15.98 kit is an additional $ 25.95 for the bushing, key, nut and 3 washers, which seems outrageous. Anyways, anybody know what size woodruff key is used on this distributor? Thanks in advance for any help you can provide.
JD Part number 26H3 (was 26H3R) shows up in a couple places as 3/32 x 3/8.
yep that's the part number...couldn't find the size listed. Thanks.
I am not guarantying the size is right. That size showed up on a couple vendors when I searched the part number. Measure the width of the slot and see if it is 3/32 wide. The length of the slot is likely 5/16 or a bit less for a 3/8" woodruff key.
