This post follows a previous one inquiring about lubing the front axle pivot pin. As previously mentioned my 885's front axle pivot has never taken grease. Took advantage of the front loader being off and investigated to find the grease passages packed slid with dirt and the front bushing completely gone, the pin was into the frame about .070" worth. The rear bushing was intact but worn. The pin is decent. The front axle is now out, the damage assessed and a plan in the works for oversizing the front pivot for a bushing to return the hole to standard. This whole operation would probably make Rube Goldberg proud.
Briefly, my biggest concern is how to drive and feed the 1" bar I'll be using as a boring bar. A hand held 1/2" drill sounds sketchy but is the only thing I have come up with. A collar with a set screw will be on the bar to act as a stop or depth of cut control. The front bar support will be a half inch plate hanging from the front end loader frame with a guide bushing tack welded in (this bushing will correct, hopefully, any misalignment between the loader frame and the pivot pin hole). I'm thinking of placing a feeler gauge between the collar and the guide bushing, snugging the collars set screw and then remove the feeler gauge, say a prayer and trigger the drill.
I'm open to suggestions.
