Horse power regarding electric motors.
Good thing about using a smallish generator is you can use it for other things too if you don't need the air compressor at the time.
A lot of people have been glad to have a 1600W generator . To operate the fridge , freezer , microwave , sump pump , wifi router and charge phones .
Best I recall hp is a function of torque x rpm. Without going in the weeds I wonder about adequate start up torque ???? A genset to power the unit at 120 sounds easy enough. Or a 12vdc to 120 inverter but you need to figure the watt hour battery storage capacity and how if it can be charged fast enough
John T
Another consideration is the air pump (compressor) speed. Many recip compressors use a splash oil system to get a little oil up to the wrist pins and rings. Check with the manufacturer about the minimum speed to achieve sufficient lubrication.
