Over the last few months I have been searching for ways to adjust the rear wheels inward on my JD A on rusted axles , and all I could find is how to adjust them out , or remove them. So after some thought I came up with this method which I hope might help others.
First i removed the locking clamp and started soaking the hub with PB Blaster and Superzilla. After a few days, of constant soaking , I constructed a puller by attaching a chain to the studs on either side of the axle frame , and attaching a threaded rod to the chain , and passing the rod through the hub. I jacked up the wheel and added nuts to the threaded rods and tighten them down as tight as i could. I also was hitting the hub with a 5 pound hammer, but not real hard. After a 10 to 20 min I let it rest and returned after a few hours and repeated the process of tightening the nuts and soaking with PB Blaster and hitting with a hammer..
After about 8 hours of doing this off and on, I started to see some movement of hub about a 1/4 inch. I continue to soak it every day and tighten the nuts and hit wit a hammer when I had time. After a few more days, the hub had moved about an 3/4 ion an inch. Now When I tightened the nuts I could actually see some movement of the hub. After some more soaking and hitting with a hammer, I had the wheel moved in a total of three inches so that my tire was 36" from the center line.
Now to keep the hub from moving back out when I start driving, I drilled a 1/4 in hole through the axle and inserted a bolt. This will keep the wheel from sliding out when driving.
I hope this helps others.
