how to identify model of International tractor with i/d plate missing
I have different numbers from engine, some stamped, some cast in block. D120472269 is vertical on block, 399847-R4 is on block, 3055,049R4 is stamped on top of cylinder head. on a plate mounted vertical where engine and trans. connect is 1662819R91, 183022BRX. Is there any other place where the serial number could be found without the missing plate on side of hydraulic fluid reservoir. I'm at wits end, oh by the way the hood is missing, the tractor looks like a 574 International, but I need to be sure. Thanks Mike
399847-R4, Googled shows as clutch housing for a 574, so that would be a safe bet.
3055,049R4, shows to be a 4 cylinder diesel engine, which would have been in that tractor also.
Just had to search the numbers, google can be useful at times.
On right side of engine just above and right of top of oil filter housing, look for a machined flat surface with D-239 stamped in it.
That would indicate 574 or 674 depending on fuel pump setting. Photo of dash.
thanks, I thought I had Googled it every way, but obviously I had not. My computer skills leave a lot to be desired. One other thing I noticed was tire size, 574 came with front tire size 6.00x16, this tractor has 7.50x16, the rear on the 574 was 12.4/11x36, on this one was 16.9/14x30. Would the plate on the fuel pump have different setting from the 574. Would there be another way to tell the difference without the serial number?
Tire size means very little, 574 Row Crop had the 7.50 fronts and 36” rears with straight axles not the flange mount. I’ve seen very few of those. Have also seen 9 bolt hubs on the straight axles with 30” rears. Different versions were utilities, Row Crop, tobacco specials, etc
