Hydro 84 Wont go in reverse
mwohletz
I have a hydro 84 that will no longer go in reverse. I checked the pressure on the forward reverse valve and get very low pressure in reverse but have normal pressure in forward. Thinking this may be a check valve, I have swapped the vales from each side that are the same in the center section and also have swapped them in the forward reverse valve. Forward reverse valves are not the same so they were from another unit. I'm at a loss as to what I should be looking for next on this thing. Images of the pressure readings included. Works great as long as you never need to back up!
