John Saeli
When we provide a Diesel Engine Kit, I always lecture the customer to NOT let anyone Grind Valves & Seats. I tell them "If the man at the machine shop says he will grind the valves & seats, then pick the heads up off the counter and get out of there, because he does not know what he is doing. The principle is the same for any diesel.
When you grind valves and seats, the valves are recessed into the head, opening up the combustion chamber area, lowering compression. CASE says that for every .005" valve recession, you lose .1 in compression. That's per valve!!
2 months ago we provided a kit for a 188 Diesel. A month later the customer called back complaining the engine wouldn't start, just smoke. We go through everything over the phone. I asked about the valves but didn't get an answer only he took it to the best shop in 3 states. Heard that before. He pulls the head and gets back, and the valves are way sunk it. This is the 4th time in 12 years that this has happened. When I ask, "Didn't you hear my lecture?" "Yes, but the man at the shop said you was full of $hit." We have another customer who's shop says I'm "full of $hit". This customer has a '70 Series Diesel and he is very satisfied with his tractor because he doesn't have to use the manifold heater until it gets below 50F.
The 188 customer got his head back, done right this time, and he called to tell me she starts excellent.
When you spend all that $$$ on the lower end, wouldn't you want the valves right? ACG (Loren) used to say he wants the valves to "Stand Proud". How right he was!! Our 730 & 800 will start @ 40F in 5 seconds, no heat. Our 630 and the rest of them here will start @ 25F or colder in 5 seconds. Good batteries are a must.
