Harold Hubbard
I spent the last four days cleaning up from the latest snowstorm. Everything finished and headed home.
“ I guess I’ll see if I can plow across the field to Bruce’s camp.”
Wrong!!! Slid off the entrance and got hung up. No problem, I’ll go start the MF175 and pull it out. Called my son to help me.
Decided to plow out the entrance s little more with the tractor, had to bucket walk myself back out the first two times I went in. Hooked on to the truck, and just succeeded in pulling it a little farther off the track.
Drove the tractor up the road, turned in and fought my way across the field, got in front of the truck, and plowed a path. Then hooked the truck from the front, started going with it and got the tractor off into the deep snow. Unhooked, thrashed around, got back on the track and finally got it out. Then I nearly went off two or three more times trying to back the truck up into the road.
Drove in there at about 4:05, got home at 7:15.
Massey Ferguson 175 diesel, loader, loaded tires, back blade with three IH wheel weights hanging on it, and skidded ring chains, still nearly helpless on hard frozen ground. And this snow is cold and dry and gives no footing, like driving on loose sand.
