Identify Carb
Hello. Back again for more assistance with my 1961 International 340 Utility. Not sure if the carb is original, but i would like to rebuild it. i see there are numerous models of Marvel Schebler carbs, and i'm not sure which one this is and which kit i should be ordering. if anyone can help identify using the below photos i would appreciate it. yes, it is filthy. need to remove, clean, rebuild. Thank you for the assistance. this place is a wealth of knowledge.
On the back side of the carb as in to see it you have to remove them carb there should be a brass tag with the carb numbers. One way to get the right carb kit is to take the carb with you to an O'Reilly's auto parts store so you can match gasket sizes. The kits they sell have enough gaskets to rebuild to different size M/S/ carbs
Clean the tag, shown in your fourth picture, and you will find the carb number.
marvel schebler. As said before the part number is stamped on the brass disc. If originally outfitted on an IH product it'll have a xxxxxxR1, R91, etc. part number.
