Identify old Bush Hog Model
Analyte
I looking to pickup this bush hog brand cutter, and I'm unable to pin down the specific model.
The seller called it a model 501, but I'm unable to to find anything using that information. Looking at old pictures online, it appears to more closely match a model 600 or a model 266. It's definitely looks heavy duty. It does use a slip clutch and has a stump jumper if that helps
The tag is missing so that's no help, but is anyone able to better identify this cutter? Thanks
To help anyone else that follows, with further research online plus part numbers off the gearbox I've got it down to either a model 502 or model 600.
I'm just not finding enough to further differentiate between the 502 and 600.
Well, after all that I ended up buying a model 600. Seller had two, and this one was in better shape. I didn't need the removable side on the cutter that appears to be a 502.
The 600 has a 6446 gearbox, rebuilt slip clutch and a new driveshaft. Very old and well built so it should be the last one I buy.
