Pressure regulator is under plug 31. CNHI IH 2504 parts catalogHigh pressure is caused by a stuck (or shimmed by the owner) pressure regulator. the pressure can be in the 70s on IH tractors. I could not find any pressure regulator on the parts diagrams. Others may know. Jim
I'll bet the valve is STUCK inside. Try CRANKING engine with the starter and see if it will move any while the cap and spring are off.I pulled that relief plug..all i get out of there is the spring. I tried a strong magnet in the hole but it won't pull anything out. Should i get the plug below the spring too?
Yes. The actual valve is down there. (from looking at the parts diagram supplied above) It is hollow and should come out. One thing to try is putting the plug back in W/O the spring, and starting it for 10 seconds. If the oil pressure stays up. that valve may be stuck firmly. if it does not go up, the valve may have freed up and be loose in the hole.I pulled that relief plug..all i get out of there is the spring. I tried a strong magnet in the hole but it won't pull anything out. Should i get the plug below the spring too?
Mine has 45/50 PSI after a cold start..Custom slide hammer ground to fit pulled it out. Now i guess I'll polish it up and stick back down the hole and try it again
Dang. I never thought in a million years that would be the problem.Ya for 35 lbs oil pressure
If an injector is stuck OPEN, that will make a loud knock also on that engine, a redneck test is to remove all four injector lines at injectors then crank engine, there should be NO compression air blow back out the injector inlet, if there is, that injector needs repair.I drive this tractor around today and the oil pressure stayed at 35lbs... Temp got up to about 180° and believe it or not it quit blowing a ton of smoke out of it. It still is really noisy and something is knocking. As soon as i get the oil pan off I'm sure I'll see what is knocking or broken. Working on getting the steering cylinder off so i can drop the pan
