Removing the Independent PTO to repair the bands. Removed the 4 long bolts. Able to move the PTO back and forth but only 1/16 inch back. Pried on it pretty good but no more movement.
Next I decided to remove the rear cover per instructions in manual. Removed all the short bolts around the edge and then the 3 around the retainer plate that holds seal on the PTO Shaft.
Then I attempted to use my 3 bolt yoke type puller to pull the rear plate. Puller was too small
Looked online for a bigger 3 bolt yoke puller but did not find anything.
What type of puller have you used to pull the rear cover?
Any suggestions to remove the PTO
