IH 560 Standard/Wheatland Power Steering schematic
Would anyone have or could point me to a link for a schematic showing an installed power steering set up on an IH 560 standard/wheatland? Appreciate any help. Even if you have one of these tractors with PS on it already, pictures would be very helpful. Thank you
Yes what do u need ? Do u have the pump in it already for p s ? Then there is a line to connect to that pump housing on the outside. I have a few of them tractors with p s.
I assume you have a parts catalog, if not here is a link to the online catalog. I don’t know if you have a gas or diesel. When you open it don’t go to the very top down a bit is a box below “Search Parts Catalog” type 560 in there and the International 560 has or diesel will be there to select. CNHi parts catalog
Great pic and schematic!!! Thank you so much. Looking at both pieces of info, does the pump attach to the back of the #30 mcv plate or is it mounted under the hydraulic remote valves?
Sorry for asking so much. It would be nice to find a copy of that manual you have.
the pump is behind that plate under the starter. need to unbolt the plate and the pump is in side bolted to that plate. where them lines are
Hi Rustred, quick question: Is there any way to tell if there could already be a PS pump in my 560 without draining oil and taking the mcv cover off? I doubt it does since there was no PS kit on it in the first place, but figured I’d get your feedback. Thanks again
good question as i never thought of that. maybe remove that little plate on the small line and see if it pumps oil when cranking it. and also drive the tractor on a ramp or blocks to that side is higher like about 10 inches then you dont loose much oil removing the cover. the power steering pump is longer also.
