international 234 mounted picker
Mounting 234 international picker on a international 706 tractor pto is to close . How to fix ?
do you have the 540 o the 1000 rpm pto drive? if you have the 540 pto drive the pto output shafts on the early 706s were shorter by about an inch. the later 706s had the longer shafts or the output shaft could have been broken and replaced
what drive is the picker did the picker come off of a fast hitch /3point or a standard drawbar and what kind of drawbar mount is it going on? my dad had a fasthitch and the pto on the picker had a spring loaded coupler so when the subframe came up the coupler would engage and the spring held the coupler together
