LeroyTumbler
I rebuilt the clutch on my 1972 1520...new plates, spring, fingers, etc. Installed it and front and back ends reconnected without problem. After starting, did a bit of adjusting to get it to go into gear. Does so fine now. However, the dual clutch will not stop the PTO. The PTO will engage and disengage with no obvious problems but the clutch completely depressed will not stop the PTO. I tried loosening the fingers and it has made no difference. Should I tighten them instead? Full disclosure, the clutch was installed a couple years ago and the tractor has sat unused while finding a working fuel injection pump. Due to humidity and rain/heat in south Alabama, some rust is visible on the clutch assembly through the inspection port. The tractor will drive and allow me to shift gears but will not stop the PTO...
