fixitforfree
I recently had my 2040 injection pump rebuilt along with new injectors. I got it started without issue but I’m pretty sure the timing is off. It doesn’t sound right. It sounds like it has a miss. When I disassembled the pump from the tractor I made sure to leave the gear as it was and didn’t crank the engine with the injection pump off. It seems to me that, by lining up the dowel pin on the pump with the slot in the injection pump timing gear how in the world can anything be off? I also marked the engine relative to the pump flange so that didn’t change. I’ve only let the tractor idle about 5 minutes or so since I got it running after the new pump so maybe I just need to let it run more to fully purge the fuel lines? Or is it more likely I jumped a single tooth one way or the other when I reinstalled the pump even though I was extremely mindful to not make that mistake when I put the pump back on the tractor? I just need experienced help with suggestions. Thanks.
