MaverickM23
Early JD 4020 diesel 24 volt, I rewired this entire tractor 2 years ago and everything has worked perfect until last night. Was picking corn and turned on the lights to the first position which should be all on but the outer two on the fenders were super bright but the inner two and the rear were dim and only measured 6 volts. Switch to the next position and all fender lights are bright but no back light, switch to the third position and all lights go out. I'm thinking its a switch issue but curious to see what others thought. Other weird thing is when I turn the key to on the gen light comes on but not the oil light but when I switch the light switch to the first position the oil light glows bright, this is all without starting the tractor. The lights and all gauges had worked perfect until now. Any ideas? Thanks
