powerplusdude
I recently purchased a JD 469 Baler and had a bearing go out on my lower belt staggering roller. The previous owner (I assume) replaced one of the arm roll threads bar bolts in the roller with a SAE threaded bolt. I replaced both bearings. When reinstalling, I attempted to use the right (metric) bolt in the hole to no avail. I then decided to use the same SAE bolt that came out off it and reamed it off with a cordless impact before it bottomed out on the bolt's washer. What is everyone's opinion? Should I try to get the broke bolt out, drill and tap the hole for a bigger bolt? Or should I buy a new Arm Roll Threads Bar? Mainly wondering if it is feasible to fix or just start over.
Thanks,
Mike
Thanks,
Mike
