TheBartman47
Oil is leaking out the side where the PTO clutch shaft sticks out... looks like it would simply be replaced from the outside, wouldn't have to take the PTO housing apart. Anyone able to confirm? Also, is there an oil seal between the PTO area and the transmission housing? I might have oil from the transmission getting into the PTO housing, but not sure. They were both a bit frothy as if they got water mixed in with the oil. I suppose rain water could have got in the PTO housing through the leaky clutch shaft oil seal, or could have just been condensation in both PTO and transmission housings. After replacing the oil seal on the 3-point hitch load sensor shaft, there doesn't appear to be any water getting in the hydraulic oil anymore.
