I'd appreciate help with this older JD401B 3pt lift. I've read everything I could find on this forum but can't quite pinpoint the problem. The lift rises so slowly you can barely see it move. I haven't put guages on the transmission pump but the main pump seems good. I adjusted it up from 2100 psi to 2250 and it seems steady. I've checked pressure at the pump, at the pressure control valve and at the port on the right side of the rockshaft. The oil at the rockshaft port had air in it...looked foamy. Not sure if it's a problem, but may be a clue.
I've replaced the trans filter and screen and cleaned the main pump screen. I repaired a broken pin in the oil filter relief valve, which got the steering, brakes, and pto going. The brakes work OK but require pumping.
Right now, I have the rockshaft off and mostly disassembled. The main piston bore looks unscarred and I've ordered a ring/gasket. Two things I'm guessing could still be the culprit now are the control valves in the rockshaft or maybe the pressure control valve I've seen referred to as priority valve. I havent found much info on either of these ...at least not yet. Any suggestions on where to go from here or if I missed anything obvious?? Thanks
