John Deere 1010 clutch issue.
Tinmann275
John Deere 1010 gas tractor with a clutch that will not fully disengage. It sat for a couple years, not running. Made some motor repairs, new pilot bearing, throw-out bearing and friction disc. Motor runs great, if it is started in gear, it tries to creep forward. If started in neutral, it’s impossible to get into any gear. I used the JD 227 gauge to adjust the pressure plate. I understand that this is a non-synchronized transmission. If I start it in gear, I am unable to shift to another gear without shutting the motor down. I ‘ve seen a couple similar threads with similar issues. Would anyone have advice to return my raking tractor to operation? Please and Thank you. Happy holidays.
Welcome to the Ford board. Suggest you repost this in the JD forum.
Tinmann.., welcome to YT! Click the “Ford with the arrow to it’s left at the upper right, then click Manufacturers, then you can scroll down and find the John Deere forum. Repost this there. You can also click the Contact Us in red below and request the moderator to move the thread to the JD forum as well.
