John Deere 1010 throttle controls
does anyone have a picture of their 1010 tractor column control for the throttle? Mine is missing and I’m looking for a picture to see what is and what isn’t there any help would be appreciated
I’ll attach pictures of what mine has or doesn’t have
Thank you
Looks to me like you're missing part of the linkage and the hand throttle lever. You're missing parts 18, 30, 63, and 23, 25, 26, 27, 28, 29 from the parts diagram. Here's the link: https://partscatalog.deere.com/jdrc/sidebyside/equipment/59702/referrer/navigation/pgId/152603
Looks like you can still get the linkage parts used/through generic parts. You should be able to order a whole new throttle lever off eBay or other used parts sites. If you don't want to pay for original lever you can always just hammer a wooden dowel in the hole that juts out off the steering column and use that for the leverage needed to move the throttle.
FYI, the linkage that's currently present on the tractor is probably going to be pretty locked up if it hasn't moved in a while. The large bolt in your second picture can be loosened to try and help, but it may be beneficial to remove that whole spring assembly and clean it up. You may also need a new throttle cable if its locked up as well.
Hope this helps.
Awesome thank you. I used a pry bar on the column and it moves just really tight.
Remove the steering wheel and then you can remove the throttle lever base. Mine had a bunch of rust and dirt in it so I sanded it smooth and then put wheel bearing grease between the mating surfaces. Helps a lot.
