I have a 1020 that's giving me problems. It start, ran fine for a half hour then starting slowing down and died. It will restart and gets up to speed but after 30 seconds it slows down and dies. It will keep repeating the process many times. I checked the usual things, good fuel flow from the tank, installed a new fuel filter and gets good flow from the filter to the pump. I unscrewed the return line on top of the pump and it makes no difference. When I bought the tractor about 4 years ago it ran and died but I found the flex ring was breaking down, I replaced it and it's been running fine until now. When I remove the check valve from the top of the pump, there is no sign of any particles, just clear fuel. It is a Roosa DB pump. Any ideas? Could the electric shut off be causing trouble? Thanks
