20BlackburnJa
Hello, I think I'm posting this the question the right way, only my second posting and first time using the new layout. Anyways, I removed the belt pulley/clutch assembly off of my John Deere 60 propane to replace the clutch bearing and the bushing. I replaced said bearing and bushing and am now trying to reinstall the assembly back on the crank shaft. I can not get it far enough to where the bearing is even touching the inner race that's preontalled on the crank. It's like the bushing is too tight to slide on the crank. I even tried ever so slightly beveleing the bushing with a drimel to help it slide on. It came off super easy so I'm thinking im either missing something or the bushing is too tight for the crank. Any advice or suggestions would me much appreciated. Thank you- Jacob.
---- the red fluid is assembly lube I oiled the bearing and bushing with.
