Keith Molden
I bought this tractor this spring at auction. Tractor runs when pulled but I can't get the starter to work. When I bench test it, it works fine but when I put it on the tractor nothing. I'm getting 6.25 volts on my multimeter. I've used emery cloth on the mating surfaces of the tractor and starter. I put new brushes in it and everything seems good till I mount it. I bench tested it with the for lack of a better word, foot kicker lever and contact switch mounted and it worked. Put it on the tractor and get nothing. I connected the battery charger directly to the starter and it just hums. I'm stumped, I'm reasonably sure it's a 6 volt starter, if I remember correctly the 12 volts tags are orange and say 12 volts on them. This one has a green tag but does not say 6 volt. I'm all out of ideas and hoping somebody has a answer. Thanks guys, Keith
